NAT over a LAN-LAN VPN
I have a VPN tunnel between two routers. My router also connects directly to internet [aDSL].
I need to PAT my inside host [192.168.0.2] to the outside interface when connecting to the internet.
I also need to static NAT my host to 172.25.100.230 when going over the VPN.
The NAT-VPN works fine on its own, and the PAT-internet connection works fine on its own.
How do I get both working together?
I've tried the following config and it doesn't work:
ip nat pool MOBILE 172.25.100.230 172.25.100.230 prefix-length 32
ip nat inside source route-map INTERNET interface Dialer1 overload
ip nat inside source route-map MOBILE-NAT pool MOBILE
route-map INTERNET permit 10
match ip address 124
route-map MOBILE-NAT permit 10
match ip address 123
access-list 123 permit ip host 192.168.0.2 host 101.123.101.123
access-list 124 permit ip 192.168.0.0 0.0.0.255 any
Thankyou all,
1 REPLY
Gold
Re: NAT over a LAN-LAN VPN
acl 123 is actually part of the acl 124, so the packet destined for 101.123.101.123 will be matched with both acl.
the route-map may act like acl meaning that it works in order. try to apply the route-map "mobile-nat" first, then route-map "internet".
99
