NAT/PAT problem
My pix have 3 interfaces:inside,outside and dmz.I have configured multi-PAT between inside and outside via saming NAT ID.But now I want translate all my internal network addresses to dmz with ONE PAT address with following command:
(conf)#nat (inside) nat_id 0 0
(conf)#global (dmz) nat_id xx.xx.xx.xx
The result is if the internal address has been added to the nat (inside -> outside), it can't reach the dmz.But the static and other internal address can work.Why?
Does nat conflict with different NAT ID translate?
Re: NAT/PAT problem
This should not be the case and the following should work
nat (inside) 25 0 0
global (outside) 25 10.10.10.10
global (dmz) 25 20.20.20.20
Have you tried clearing the translation (clear xlat)?
Nadeem
Re: NAT/PAT problem
Thanks for answering.If the configuration like follow:
nat(inside) 25 0 0
nat(inside) 26 10.10.1.0 255.255.255.0
nat(inside) 27 10.10.2.0 255.255.255.0
global (outside) 26 10.10.10.11
global (outside) 27 10.10.10.12
I would like using only one PAT address in dmz for addressing saving.But the address in net 10.10.1.0/24&10.10.2.0/24 can't reach the dmz.
can you give me some advise for resloving the problem?
Thanks.
Re: NAT/PAT problem
Try to add the following two as well
global(dmz) 26 20.20.20.20
global(dmz) 27 20.20.20.20
I hope this should fix the issue.
Nadeem
Re: NAT/PAT problem
Hi,I try to add just like your advise,but the system info:global for this range already exists. So can't use one global address for multi-translation.I use pixos 6.3.3.
Re: NAT/PAT problem
If you only have one NAT pool defined then this could be a problem.
Re: NAT/PAT problem
You are right, it is not letting add these globals
then try to add these
global (dmz) 26 20.20.20.21
global (dmz) 27 20.20.20.22
I hope this will help
Nadeem
Re: NAT/PAT problem
hi,thanks for your advises.At the last, I had to do just like what you said,allocate many REAL ip address for inside usres visiting dmz.
116
