Community Member
Nat Problem with vpn client 3.5
Hi, I have serious problem with my clients Vpns. When I connect I can access to all my network wtih out problems but when I want to access to ip address that have a Nat Translation in the router I can´t.
Any Body can help me.
Thanks, regards
My configuration, I only have problems with the ip address with nat
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname CISCOADSL
aaa new-model
aaa authentication login userauthen local
aaa authorization network groupauthor local
aaa session-id common
enable secretxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
enable password xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
username COMAcceso password xxxxxxxxxxxxxxxxxxxxxxxxxxx
username voiceware password xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group rasvpn
key xxxxxxxxxxxxxxxxx
pool ippool
acl 102
crypto ipsec transform-set ras-transform esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10
set transform-set ras-transform
crypto map clientmap client authentication list userauthen
crypto map clientmap isakmp authorization list groupauthor
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
interface Loopback0
no ip address
interface Ethernet0
ip address
ip nat inside
no ip mroute-cache
hold-queue 100 out
interface ATM0
no ip address
no ip mroute-cache
no atm ilmi-keepalive
pvc 0/33
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
hold-queue 224 in
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool 1
ppp authentication chap
ppp chap hostname xxxxxxxxxxxxxxxxxxxxxxxxxxx
ppp chap password xxxxxxxxxxxxxxxxxxxxxxxxxxx
ip local pool ippool
ip nat inside source list 101 interface Dialer0 overload
ip nat inside source static tcp 25 25 extendable
ip nat inside source static tcp 80 80 extendable
ip nat inside source static tcp 110 110 extendabl
ip classless
ip route Dialer0
no ip http server
ip pim bidir-enable
access-list 101 deny ip
access-list 101 permit ip any
access-list 102 permit ip
line con 0
stopbits 1
line vty 0 4
scheduler max-task-time 5000
Re: Nat Problem with vpn client 3.5
Often times complex troubleshooting issues are best addressed in an interactive session with one of our trained technical assistance engineers. While other forum users may be able to help, it’s often difficult to do so for this type of issue.
To utilize the resources at our Technical Assistance Center, please visit and to open a case with one of our TAC engineers, visit
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
