NAT-T config problem
Hi. We are currently configuring an ASA5510 running v8.0(2). We have setup NAT traversal for ipsec using:
crypto isakmp nat-traversal 20
This works fine. The problem is, whenever I write the config (write mem) it doesn't retain this setting in the startup-config. A "show running-config" immediately after a reload contains the line:
no crypto isakmp nat-traversal
If I edit the config in a txt editor, and add "crypto isakmp nat-traversal 20", then copy it to startup-config, it works. This isn't sufficient though, as it only lasts until the next time the config is updated by a "write mem" command, whereby it is disabled again.
Is this a bug in 8.0(2)? Is there any way to add a persistent entry in the ASA config that is *always* retained when a "write mem" command is issued? Any help/advice appreciated.
Thanks.
1 ACCEPTED SOLUTION
Re: NAT-T config problem
Yes a bug has been filed for this:
CSCsj52581
Check details about the bug here:
http://www.cisco.com/cgi-bin/Support/Bugtool/home.pl
~Rohit
CSCsj52581
~Rohit
Great, that's all I needed to know. Thanks for the info.
122
