10-15-2003 02:58 PM - edited 03-09-2019 05:10 AM
Cisco PIX Firewall Version 6.3(1)
model: 515e
Is is possible to have the PIX use PAT for outbound traffic, like FTP and HTTP to any IP address, but then have it use NAT only to a few specific destinations?
Here is the problem I have which may help explain the question:
I have client PC's that need to access a remote site to another company via Nortel VPN. This requires a 1-1 mapping with NAT, and no PAT. I have gotten this to work in a test env with the global commands and with static commands. The problem I have is; there are more client computers that need access to the VPN than I have public IP's, but not all the clients use the VPN software at the same time.
So effectively what I want is:
an access-list that uses PAT for all regular traffic
and
an access-list that says:
if traffic is going to destination x.x.x.x, then use the global pool of x.x.x.1-x.x.x.20.
I know this is possible with Netscreen firewalls, I just hope it is with the PIX as well.
Dan
10-15-2003 05:44 PM
Hi Dan,
Please check out the policy NAT feature per this document.
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/config/bafwcfg.htm#1113601
Nadeem
10-16-2003 09:59 AM
Thanks Nadeem,
This is exactly what I need, but the FOS will not let me set it up.
I have cleared the config and started from scratch, but this still does not help. Here is what I am doing:
pix(config)# show access-l
access-list cached ACL log flows: total 0, denied 0 (deny-flow-max 1024)
alert-interval 300
pix(config)# access-l NET1 perm ip 10.1.1.0 255.255.255.0 host 12.40.x.x
pix(config)# access-l NET2 perm ip 10.1.1.0 255.255.255.0 any
pix(config)# nat (inside) 2 access-l NET1
ERROR: invalid nat ID, <2>, with access-list
Usage: [no] nat [(
[dns] [outside]
[no] nat [(if_name)] 0 [access-list
pix(config)#
I always get an error stating that the NAT ID is incorrect, no matter what I change it to. Any thoughts on this. I've done some searching, and it seems that only and "nat (inside) 0" command will work with an access-list. But it sems that this will limit my possibilites.
Dan
10-16-2003 10:49 AM
Looks like this is a feature introduced in 6.3(2).
guess I need to figure out how to get that version now.
