NAT with 2 SAME SECURITY LEVEL INTERFACES
My current setup is as follows
ASA 5510
E0/0 INTERNET
Security Level 0
E0/1 WAN (connected to Branch offices on MPLS network)
Security Level 100
E/2 LAN
Security Level 100
If i create PAT using internet interface IP for all traffic originiating from LAN, then i lose communication with subnets coming through WAN interface, I have already defined NAT exempt rules, stating that any traffic going to WAN should be exempted from NAT but they do not seems to be working. cisco documentation says i dont need any ACLs or NAT rules for communication between 2 interfaces with same security level, but its just doesnt work.
Can anyone help with this issue
Muhammad
Re: NAT with 2 SAME SECURITY LEVEL INTERFACES
The command
same-security-traffic permit inter-interface
permits communication between different interfaces that have the same security level.
http://www.cisco.com/en/US/customer/products/ps6120/products_command_reference_chapter09186a008063f0fb.html#wp1283601
Matt
Hi MATT,
thanks for your reply
That command has already active, thats why i can talk to WAN interface when NAT is not place, the problem is when i put NAT in place for internet, i lose communication with WAN interface.
Muhammad
Muhammad,
I see. Sorry, I was hoping that's all you were looking for! If you post your config, hopefully we can figure it out.
Matt
Matt,
When i have
(NAT (LAN) 1 access-list LAN_PAT ) in place i cant talk to anything on WAN interface, when i remove this rule i can talk to WAN, but can not ofcourse go to internet.
Even i have (NAT0) in place matching traffic which should be exempted from NAT.
I had to put NAT rules for LAN and WAN interfaces(same security level) to talk to each other because of using DYNAMIC NAT for INTERNET on LAN interface.
117
