Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
NDS and NAT
Apparently, you can't do an NDS authentication over a NATed/PATed environment due to that same old story about the "actual IP" being stored in the packet. Does anybody know a way around that? Would a fixup help?
TIA
Dave
1 REPLY
Silver
Re: NDS and NAT
Well, authentication based on IP is a style that the industry is generally moving away from. This trend is seen primary due to the kind of problems you are facing... i.e. incompatibility between IP based authentication and technologies such as NAT and Caching. I guess the only way is to disable one of the two. I do feel taht the long term goal should be to opt out of using IP based authentication techniques.
84
