Need help with ASA/VPN remote user problem
I am being introduced to the Cisco ASA/VPN device in a trial by fire and I need some help.
Scenario: A disaster recovery site that mimics the IP range of the home network.
Clients will VPN to DR, get an IP address and continue working just like they were at the office.
A VPN tunnel with no split-tunneling should take care of this since all traffic has to go to the ASA before being routed anywhere.
The Problem:I can get connected via VPN using AD authentication (User requirement) but I get no traffic flow. ADSM monitor shows 0 bytes TX and RX for my session. I'm hoping this is something simple that I am just missing and someone can help me out.
I've included an IP scrubbed version of the config.
Thanks! Steve
hostname ciscoasa
domain-name default.domain.invalid
enable password ************* encrypted
names
interface GigabitEthernet0/0
nameif outisde
security-level 0
ip address 10.20.47.6 255.255.255.0
interface GigabitEthernet0/1
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
Interface GigabitEthernet0/3
nameif inside
security-level 100
ip address 192.168.157.6 255.255.255.0
interface Management0/0
shutdown
no nameif
no security-level
no ip address
passwd *************** encrypted
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
access-list inside_nat0_outbound extended permit ip any 192.168.131.0 255.255.255.0
access-list outisde_cryptomap_dyn_20 extended permit ip any 192.168.131.0 255.255.255.0
access-list inbound extended permit ip any any log
access-list inbound extended permit icmp any any log
pager lines 24
logging enable
logging timestamp
logging buffer-size 1048576
logging buffered informational
mtu inside 1500
mtu outisde 1500
ip local pool AdminAccessPool 192.168.131.1-192.168.131.254 mask 255.255.255.0
no failover
icmp permit any outisde
asdm image disk0:/asdm-504.bin
no asdm history enable
arp timeout 14400
nat (inside) 0 access-list inside_nat0_outbound
access-group inbound in interface outisde
route outisde 0.0.0.0 0.0.0.0 10.20.47.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server AdminAccessNT protocol nt
aaa-server AdminAccessNT host 198.76.0.26
timeout 5
nt-auth-domain-controller dc1
group-policy AdminAccess internal
group-policy AdminAccess attributes
wins-server value 192.168.3.249 192.168.3.250
dns-server value 192.168.159.9
default-domain value foo.blah.com
webvpn
http server enable
http 0.0.0.0 0.0.0.0 inside
http 0.0.0.0 0.0.0.0 outisde
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outisde_dyn_map 20 match address outisde_cryptomap_dyn_20
crypto dynamic-map outisde_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map outisde_map 65535 ipsec-isakmp dynamic outisde_dyn_map
crypto map outisde_map interface outisde
isakmp enable outisde
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
isakmp policy 65535 authentication pre-share
isakmp policy 65535 encryption 3des
isakmp policy 65535 hash sha
isakmp policy 65535 group 2
isakmp policy 65535 lifetime 86400
tunnel-group AdminAccess type ipsec-ra
tunnel-group AdminAccess general-attributes
address-pool AdminAccessPool
authentication-server-group AdminAccessNT
default-group-policy AdminAccess
tunnel-group AdminAccess ipsec-attributes
pre-shared-key *
telnet timeout 5
ssh timeout 5
console timeout 0
443
