04-20-2004 03:11 PM - edited 03-09-2019 07:07 AM
I have a simple network and I need to redirect http and 8080 ports to web server but it won't work. I can't download anything from web either. Can someone check my config and tell me what's wrong with it?
network: lan - pix - wan
ip: static
config: attached
Thanks!
04-20-2004 04:45 PM
Okay, after looking at your config here are some things I see:
Your access-list on the inside interface:
access-list 100 deny tcp any object-group ms-ports any
access-list 100 deny udp any object-group ms-ports any
access-list 100 permit tcp any any
access-list 100 permit udp any any
access-list 100 deny tcp any any <----get rid of this
access-list 100 permit ip any any <----get rid of this
access-list 100 deny ip any any <--with this protocols like gre, esp and so on will not make it out. only tcp and udp protocols.
access-list 101 deny tcp any object-group ms-ports any <---you dont need this. ASA already denies them.
access-list 101 deny udp any object-group ms-ports any <---you dont need this. ASA already denies them.
access-list 101 permit tcp any eq www interface outside eq www <---Remove the first "eq www" The source port is dynamic.
access-list 101 permit tcp any eq https interface outside eq https <---Remove the first "eq https" The source port is dynamic.
access-list 101 permit tcp any eq 8080 interface outside eq 8080 <---Remove the first "eq 8080" The source port is dynamic.
access-list 101 deny tcp any any <---remove this. Replace it with "access-list 101 deny ip any any.
Your Statics:
static (inside,outside) tcp interface www name1 www netmask 255.255.255.255 0 0
static (inside,outside) tcp interface https name1 https netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 8080 name1 8080 netmask 255.255.255.255 0 0
Normally port redirection should redirect you to different internal ports. For example:
static (in,out) tcp interface 8080 name1 www
You may be able to leave it as is if you clean up your access-lists though.
Let me know.
BC
04-21-2004 01:09 AM
04-21-2004 04:08 AM
When you changed to this:
static (inside,outside) 200.xxx.xxx.9 name1 netmask 255.255.255.255 0 0
is why you may still have the problem.
You mentioned that port 8080 is still quiet, what about ports 80 and 443 from the wan, are they quiet to? I suspect so.
See if you have any hit count for this acl entry:
access-list 101 permit tcp any interface outside object-group WEB-srv
You may need to create a seperate acl as if the inside server NAME1 was initiating the connections and changeing the static to use the acl. I'll give an example:
access-list pmap_01 permit tcp host name1 any
static (in, out) tcp interface 80 access-list pmap_01
static (in, out) tcp interface 443 access-list pmap_01
static (in, out) tcp interface 8080 access-list pmap_01
Remove this: static (inside,outside) 200.xxx.xxx.9 name1 netmask 255.255.255.255 0 0
Run the clear xlate command after modifying the statics and try to connect over the WAN. Let me know how it turns out.
