Community Member
Need help with PIX to VPN3005 connection
I have a problem with connecting remote PIX501 to my VPN3005. I followed the suggested code in the following:
http://www.cisco.com/en/US/customer/products/hw/vpndevc/ps2030/products_configuration_example09186a0080094cf8
.shtml
In following the syslog from the VPN3005, I see if gets to: PHASE 1 COMPLETED... then stops. At that point
the PIX starts to issue this statement while "debug crypto isakmp" is on: (every 10 seconds)
ISAKMP (0): sending NOTIFY message 36136 protocol 1
crypto_isakmp_process_block:src:<VPN3000 IP ADDRESS>, dest:<PIX501 IP ADDRESS> spt:500 dpt:500
ISAKMP (0): processing NOTIFY payload 36137 protocol 1
spi 0, message ID = 660117357
ISAMKP (0): received DPD_R_U_THERE_ACK from peer <VPN3000 IP ADDRESS>
return status is IKMP_NO_ERR_NO_TRANS
Below is the entire debug crypto isakmp from the PIX.
Can anybody help with this?
Thanks. - Jay
ISAKMP (0): ID payload
next-payload : 13
type : 11
protocol : 17
port : 0
length : 13
ISAKMP (0): Total payload length: 17
ISAKMP (0:0): sending NAT-T vendor ID - rev 2 & 3
ISAKMP (0): beginning Aggressive Mode exchange
OAK_AG exchange
ISAKMP (0): processing SA payload. message ID = 0
ISAKMP (0): Checking ISAKMP transform 8 against priority 65001 policy
ISAKMP: encryption 3DES-CBC
ISAKMP: hash MD5
ISAKMP: default group 2
ISAKMP: extended auth pre-share (init)
ISAKMP: life type in seconds
ISAKMP: life duration (VPI) of 0x0 0x1 0x51 0x80
ISAKMP (0): atts are not acceptable. Next payload is 0
ISAKMP (0): Checking ISAKMP transform 8 against priority 65002 policy
ISAKMP: hash MD5
ISAKMP (0): Checking ISAKMP transform 8 against priority 65003 policy
ISAKMP: hash MD5
ISAKMP (0): Checking ISAKMP transform 8 against priority 65004 policy
ISAKMP: hash MD5
ISAKMP (0): Checking ISAKMP transform 8 against priority 65005 policy
ISAKMP: hash MD5
ISAKMP (0): Checking ISAKMP transform 8 against priority 65006 policy
ISAKMP: hash MD5
ISAKMP (0): Checking ISAKMP transform 8 against priority 65007 policy
ISAKMP: hash MD5
ISAKMP (0): Checking ISAKMP transform 8 against priority 65008 policy
ISAKMP: hash MD5
ISAKMP (0): atts are acceptable. Next payload is 0
ISAKMP (0): processing KE payload. message ID = 0
ISADB: reaper checking SA 0x9e83ac, conn_id = 0
ISADB: reaper checking SA 0xa73d84, conn_id = 0 DELETE IT!
VPN Peer: ISAKMP: Peer ip:<VPN3000 IP ADDRESS>/500 Ref cnt decremented to:0 Total VPN Peers:1
VPN Peer: ISAKMP: Deleted peer: ip:<VPN3000 IP ADDRESS>/500 Total VPN peers:0
ISAKMP (0): processing NONCE payload. message ID = 0
ISAKMP (0): processing ID payload. message ID = 0
ISAKMP (0): processing HASH payload. message ID = 0
ISAKMP (0): processing vendor id payload
ISAKMP (0): received xauth v6 vendor id
ISAKMP (0): remote peer supports dead peer detection
ISAKMP (0:0): vendor ID is NAT-T
ISAKMP (0:0): Detected NAT-D payload
spi 0, message ID = 236223124
spi 0, message ID = 1914704689
Community Member
Re: Need help with PIX to VPN3005 connection
try turning off dead peer detection on the concentrator
do a 'debug crypto ipsec' because your phase1 appears to be negotiating OK.
"ISAKMP (0): atts are acceptable. Next payload is 0
ISADB: reaper checking SA 0xa73d84, conn_id = 0 DELETE "
make sure you are allowing the ipsec protocol (esp/ah), there have been instances where i have had to explicitly configure it in an acl (instead of using the sysopt command).
Community Member
If I do a "Sysopt connection ipsec-permit" I get:
pixfirewall(config)# sysopt connection permit-ipsec
ERROR: sysopt connection permit-ipsec configuration cannot be modified
with PIX Easy VPN Remote enabled.
Not sure how I would enable it in the acl as you mention.
You are correct the syslog on the vpn3000 states that phase 1 completed, but then just sits there.
debug crypto ipsec: I get the following:
IPSEC(key_engine_delete_sas): rec'd delete notify from ISAKMP
IPSEC(key_engine_delete_sas): delete all SAs shared with 12.146.xx.124
debug crypto isakmp: I get the following:
VPN Peer: ISAKMP: Peer ip:12.146.xx.124/500 Ref cnt decremented to:0 Total VPN Peers:1
VPN Peer: ISAKMP: Deleted peer: ip:12.146.xx.124/500 Total VPN peers:0
next-payload : 13
type : 11
protocol : 17
port : 0
length : 18
ISAKMP (0): Total payload length: 22
crypto_isakmp_process_block:src:12.146.xx.124, dest:12.146.xx.123 spt:500 dpt:500
OAK_AG exchange
ISAKMP: hash MD5
ISAKMP: hash MD5
ISAKMP: hash MD5
ISAKMP: hash MD5
ISAKMP: hash MD5
ISAKMP: hash MD5
ISAKMP: hash MD5
ISAKMP: hash MD5
ISAKMP (0:0): recalc my hash for NAT-D
ISAKMP (0:0): NAT match MINE hash
ISAKMP (0:0): recalc his hash for NAT-D
ISAKMP (0:0): NAT match HIS hash
spi 0, message ID = 2256657453
ISAMKP (0): received DPD_R_U_THERE_ACK from peer 12.146.xx.124
spi 0, message ID = 442225445
spi 0, message ID = 3491695105
spi 0, message ID = 4243276284
Community Member
i didn't realize you were doing ezVpn, sorry
create an access-list that allows esp and ike even though sysopt connection permit-ipsec exists
access-list 111 permit udp host 3005ExtIP host PIXExtIP eq isakmp (or 500)
access-list 111 permit esp host 3005ExtIP host PIXExtIP
access-list 111 permit WHATEVERELSEyouNEED
access-list 111 deny any any
access-group 111 in interface outside
142
