Need helping allowing trafic from outside to inside interface.
--begin ciscomoderator note-- The following post has been edited to remove potentially confidential information. Please refrain from posting confidential information on the site to reduce security risks to your network. -- end ciscomoderator note --
I am trying to set up a pix 501 in front of a few colocated web servers. So far I can see out to the internet with no problems but can not get traffic to come in even after creating my access rules. The software I am running on my web servers require that my servers use the same static IP's that our on the outside interface. My ISP created a subnet for this configuration. Any help is very much appreciated.
EXAMPLE ROUTE NOT WORKING:
outside inside
nn.nnn.7.244 255.255.255.0 ---> nn.nnn.7.244 255.255.255.240
MY NETWORK CONFIG:
Outside IP: nn.nnn.n.222
Outside GW: nn.nnn.n.1
Outside NM: 255.255.255.0
Inside IP: nn.nnn.7.241 - 255
Inside GW: nn.nnn.7.241
Inside NM: 255.255.255.240
PIX CONFIG:
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password ********** encrypted
passwd ********** encrypted
hostname firewall
domain-name --moderator edit--
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list outside_access_in permit icmp any any
access-list outside_access_in permit tcp any eq ftp-data any
access-list outside_access_in permit tcp any eq ftp any
access-list outside_access_in permit tcp any eq smtp any
access-list outside_access_in permit tcp any eq domain any
access-list outside_access_in permit tcp any eq www any
access-list outside_access_in permit tcp any eq pop3 any
access-list outside_access_in permit tcp any eq imap4 any
access-list outside_access_in permit tcp any eq https any
access-list outside_access_in permit tcp any eq 19638 any
access-list outside_access_in permit tcp any eq 19640 any
access-list outside_access_in permit udp any eq 445 any
access-list outside_access_in permit tcp nn.nnn.0.0 255.255.0.0 eq 5800 any
access-list outside_access_in permit tcp nn.nnn.0.0 255.255.0.0 eq 5900 any
access-list inside_outbound_nat0_acl permit ip any nn.nnn.7.252 255.255.255.252
pager lines 24
interface ethernet0 10baset
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside nn.nnn.n.222 255.255.255.0
ip address inside nn.nnn.7.241 255.255.255.240
ip audit info action alarm
ip audit attack action alarm
ip local pool vpn nn.nnn.7.252-nn.nnn.7.254
pdm location nn.nnn.7.0 255.255.255.0 inside
pdm location nn.nnn.0.0 255.255.0.0 outside
pdm location nn.nnn.7.252 255.255.255.252 outside
pdm logging informational 100
pdm history enable
arp timeout 14400
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 0 0.0.0.0 0.0.0.0 0 0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 nn.nnn.n.1 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
aaa authorization command LOCAL
http server enable
http 0.0.0.0 0.0.0.0 outside
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-pptp
no sysopt route dnat
telnet timeout 5
ssh timeout 5
vpdn group PPTP-VPDN-GROUP accept dialin pptp
vpdn group PPTP-VPDN-GROUP ppp authentication mschap
vpdn group PPTP-VPDN-GROUP ppp encryption mppe 40
vpdn group PPTP-VPDN-GROUP client configuration address local vpn
vpdn group PPTP-VPDN-GROUP client configuration dns nn.nnn.n.2 nn.nnn.n.3
vpdn group PPTP-VPDN-GROUP pptp echo 60
vpdn group PPTP-VPDN-GROUP client authentication local
vpdn username --moderator edit-- password *********
vpdn enable outside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
username --moderator edit-- password ********** encrypted privilege 15
privilege show level 0 command version
privilege show level 0 command curpriv
privilege show level 3 command pdm
privilege show level 3 command blocks
privilege show level 3 command ssh
privilege configure level 3 command who
privilege show level 3 command isakmp
privilege show level 3 command ipsec
privilege show level 3 command vpdn
privilege show level 3 command local-host
privilege show level 3 command interface
privilege configure level 3 command ping
privilege configure level 5 mode enable command configure
privilege show level 5 command running-config
privilege show level 5 command privilege
privilege show level 5 command clock
privilege show level 5 command ntp
terminal width 80
Re: Need helping allowing trafic from outside to inside interfac
I think you need change your acl
from
"access-list outside_access_in permit tcp any eq ftp-data any "
to
access-list outside_access_in permit tcp any any eq ftp-data
I'm afraid that did not work but thanks for your help.
it can work but don't use permit any any,
and you need use "permit any host xxx.xxx.xxx.xxx eq port"
Hmm, cant enter just a single server IP becuase it does not like the subnet (255.255.255.240) I did try to enter my subnet range (66.129.7.240 -255) but that also did not seem to work.
Anyone else have an idea?
Silver
So you need to redirect ports from the outside ip address of 66.129.1.222 to internal servers? Which server?
The problem is that you are not using NAT. I am fairly certain that if you want to redirect ports using the PIX's outside IP address, you will need to be using NAT.
I think the best idea is to try to find a way to not need to use 66.129.1.222 for any of your servers. Otherwise, you will need to NAT things. You could keep the existing IP addresses, and nat them, but also use them externally in a global pool, but this will be outrageously confusing - re ip addressing all the internal servers with RFC 1918 addresses would be much easier for future troubleshooting.
Gold
Hi -
Please read the following cisco document:
http://www.cisco.com/warp/public/707/28.html
Hope this explains it --
Silver
The problem is not with the static, provided that you have a web server that has ip add of either .253 or .254. Because with the following config, you are turning off the NAT engine on PIX for traffic from outside to .253-.254 addresses.
Problem is ACL defined wrong order of the ports. Please change:
to
access-list outside_access_in permit tcp any any eq www
Please make chnages to all the ACL lines, then execute "clear xlate".
I hope this ressolves the issue. If not, then please collect the syslog on the buffer (if you don't have syslog server).
logging on
logging buffered debug
show logging
Mynul
MyNul,
Thanks for the info, I will try that out. I have one questions for you though. The 66.129.7.253- .254 addresses where set up to be used for VPN. I'm running my server's on 66.129.7.244 - .252. Does the problem you see have to do with that range as well and will making the modifications you suggested work with that range. I would prefer to not use NAT at all and just use the Pix to block ports and for VPN.
Jack
Silver
Jack,
In that case, please make the following changes and it will work:
access-list inside_outbound_nat0_acl permit ip any nn.nnn.7.240 255.255.255.240
no access-list inside_outbound_nat0_acl permit ip any nn.nnn.7.252 255.255.255.252
In that way, you are including the web servers under the no translation rules. Please make sure to execute "clear xlate". Thanks,
Mynul
117
