11-17-2006 12:48 PM - edited 03-09-2019 04:54 PM
Hi every one
I need information about the following stream cipher,
.py
.RC4
any body knows about then, please pass me link/material.
11-20-2006 08:15 AM
Syed,
RC4 is stream cipher designed by Rivest for RSA Data Security, Inc. It is a variable key-size stream cipher with byte-oriented operations. The algorithm is based on the use of a random permutation.
http://www.rsasecurity.com/rsalabs/node.asp?id=2174
http://en.wikipedia.org/wiki/Stream_cipher
.Py
http://en.wikipedia.org/wiki/Py_(cipher)
I hope the above information helps.
Arul
** Please rate all helpful posts **
Log in to Community
