Need nat 0 explanation
I have installed PIX-515 with 3 interfaces. Inside users can access the outside and the dmz. The ip assigned to the interfaces are:
Outside: 203.115.208.1 subnet mask 255.255.255.240
Dmz: 203.115.211.1 subnet mask 255.255.255.0
Inside: 10.0.0.1 subnet mask 255.255.255.0
The web server (203.115.211.10/24) and mail server (203.115.211.11/24) use valid internet ip addresses.
The question is how I go about to configure nat 0 for web and mail server?
1 REPLY
Silver
Re: Need nat 0 explanation
The NAT 0 command is mainly for outbound access. You can use "nat 0 (interface) access-list " to accomplish what you wish, but I would suggest just using static statements. In your case, they would read:
static (dmz, outside) 203.115.211.10 203.115.211.10 netmask 255.255.255.255
static (dmz, outside) 203.115.211.11 203.115.211.11 netmask 255.255.255.255
The above statements create static translations from the dmz to the outside for those two hosts. The addresses will not be translated because the address on the dmz is the same as the one we specified on the outside.
Don't forget to add an access-list to the outside interface to permit access to those servers.
Hope that helps,
David.
93
