Need suggestion
Hi all,
I have a small network and need to deploy firewall. can you suggest me the model of a firewall which has two ethernet interfaces and can be an entry level.
Suresh
Re: Need suggestion
I would suggest to have a look at PIX 501 series but you need to go thru the licensing information before obtaining one for the equipment.
you gotta different variable license available for the box and u can very well decide upon for the best bet which can fullfill ur requirmenet.
do refer these links for more info on PIX 501 as well as other models available..
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_data_sheet09186a0080091b18.html
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_data_sheets_list.html
regds
Gold
Re: Need suggestion
there are two models with only two interfaces, namely pix 501 and pix 506e.
without a doubt, 506e would have a better performance. i guess the way to decide which one to purchase is relying on the number of vpn.
501 supports 10 simultaneous vpn peers; whereas 506e supports 25.
for pix501 spec,
for pix506 spec,
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_data_sheet09186a0080091b13.html
102
