Need to allow passage of the following two ip addresses
I need to allow the following the two ip address to pass from the outside world thru our PIX515e firewall.
I keep getting an error on ip and subnet mask when I try to enter these.
Does anyone know the correct syntax?
The ip address that I need to allow any access for are;
207.236.99.201
192.206.158.10
Any help or advise or suggestions is greatly welcome!
TIA,
Gary
  • Other Security Subjects
1 ACCEPTED SOLUTION
Re: Need to allow passage of the following two ip addresses
access-list (name) permit ip 207.236.99.201 255.255.255.255 any
access-list (name) permit ip 192.206.158.10 255.255.255.255 any
substitue (name) with what you want to call the access-list.
This will allow unrestricted access from those IPs to all internal destinations. If you want to restrcit to certain hosts substitue the any with the IP address and subnet mask.
Then apply the access-list to your outside interface:
access-group (name) in interface outside
hth & please rate.
hth & please rate.
THANK YOU
103
