Need your kind help on CSM
HI All,
I need your kind input on the below querries.
We have to use Cisco Security Manager 3.1 for Security monitoring and CiscoWorks LMS for network monitoring. My question is
1)can we Install both this software in a single server ?
2) what is the minimum requirement of the Server (Hardware Spec of the server to install the CSM software) ?
3) Can we install CSM or LMS 2.6 on Windows 2008 Entreprise Server plat form?
regards
Jacob
1 REPLY
Re: Need your kind help on CSM
Hello Jacob!
CSM doesn't act as a Security Monitoring device!!! The CSM doesn't have this functionality, instead of it CS-MARS has.
Otherwise, you have to install the CSM and the LMS to a separate server!
By(e) Miki
121
