Negotiation tunell between AIX and 2651
This is the debug output for ipsec and isakmp on c2651. It seems aphase 2 is failing but I'm not able to guess why. Could anay body help me?
Could anybody tell me the meaning of "invalid proposal flags - 0x0"?
Thanks in advance..
VPN2651#debug crypto isakmp
Crypto ISAKMP debugging is on
VPN2651#debug crypto ipsec
Crypto IPSEC debugging is on
VPN2651#
01:35:30: ISAKMP (0:0): received packet from 172.16.21.228 (N) NEW SA
01:35:30: ISAKMP: local port 500, remote port 500
01:35:30: ISAKMP (0:1): Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
Old State = IKE_READY New State = IKE_R_MM1
01:35:30: ISAKMP (0:1): processing SA payload. message ID = 0
01:35:30: ISAKMP (0:1): found peer pre-shared key matching 172.16.21.228
01:35:30: ISAKMP (0:1): Checking ISAKMP transform 1 against priority 1 policy
01:35:30: ISAKMP: encryption DES-CBC
01:35:30: ISAKMP: hash MD5
01:35:30: ISAKMP: auth pre-share
01:35:30: ISAKMP: default group 1
01:35:30: ISAKMP: life type in seconds
VPN2651#
01:35:30: ISAKMP: life duration (VPI) of 0x0 0x1 0x51 0x80
01:35:30: ISAKMP (0:1): atts are acceptable. Next payload is 0
01:35:30: ISAKMP (0:1): Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
Old State = IKE_R_MM1 New State = IKE_R_MM1
01:35:30: ISAKMP (0:1): sending packet to 172.16.21.228 (R) MM_SA_SETUP
01:35:30: ISAKMP (0:1): Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
Old State = IKE_R_MM1 New State = IKE_R_MM2
VPN2651#
01:35:38: ISAKMP (0:1): received packet from 172.16.21.228 (R) MM_SA_SETUP
01:35:38: ISAKMP (0:1): phase 1 packet is a duplicate of a previous packet.
01:35:38: ISAKMP (0:1): retransmitting due to retransmit phase 1
01:35:38: ISAKMP (0:1): retransmitting phase 1 MM_SA_SETUP...
01:35:38: ISAKMP (0:1): incrementing error counter on sa: retransmit phase 1
01:35:38: ISAKMP (0:1): sending packet to 172.16.21.228 (R) MM_SA_SETUP
01:35:38: ISAKMP (0:1): Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
Old State = IKE_R_MM2 New State = IKE_R_MM3
01:35:38: ISAKMP (0:1): processing KE payload. message ID = 0
01:35:39: ISAKMP (0:1): processing NONCE payload. message ID = 0
01:35:39: ISAKMP (0:1): found peer pre-shared key matching 172.16.21.228
01:35:39: ISAKMP (0:1): SKEYID state generated
VPN2651#01:35:39: ISAKMP (0:1): Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
Old State = IKE_R_MM3 New State = IKE_R_MM3
01:35:39: ISAKMP (0:1): sending packet to 172.16.21.228 (R) MM_KEY_EXCH
01:35:39: ISAKMP (0:1): Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
Old State = IKE_R_MM3 New State = IKE_R_MM4
01:35:39: ISAKMP (0:1): received packet from 172.16.21.228 (R) MM_KEY_EXCH
01:35:39: ISAKMP (0:1): Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
Old State = IKE_R_MM4 New State = IKE_R_MM5
01:35:39: ISAKMP (0:1): processing ID payload. message ID = 0
01:35:39: ISAKMP (0:1): processing HASH payload. message ID = 0
01:35:39: ISAKMP (0:1): SA has been authenticated with 172.16.21.228
Old State = IKE_R_MM5 New State = IKE_R_MM5
01:35:39: ISAKMP (0:1): SA is doing pre-shared key authentication using id type ID_IPV4_ADDR
01:35:39: ISAKMP (1): ID payload
next-payload : 8
type : 1
protocol : 17
port : 500
length : 8
01:35:39: ISAKMP (1): Total payload length: 12
01:35:39: ISAKMP (0:1): sending packet to 172.16.21.228 (R) QM_IDLE
Old State = IKE_R_MM5 New State = IKE_P1_COMPLETE
01:35:39: ISAKMP (0:1): Input = IKE_MESG_INTERNAL, IKE_PHASE1_COMPLETE
Old State = IKE_P1_COMPLETE New State = IKE_P1_COMPLETE
VPN2651#
VPN2651#
01:36:22: ISAKMP (0:1): received packet from 172.16.21.228 (R) QM_IDLE
01:36:22: ISAKMP (0:1): processing HASH payload. message ID = -1877728890
01:36:22: ISAKMP (0:1): processing SA payload. message ID = -1877728890
01:36:22: ISAKMP (0:1): Checking IPSec proposal 1
01:36:22: ISAKMP: transform 1, ESP_DES
01:36:22: ISAKMP: attributes in transform:
01:36:22: ISAKMP: SA life type in seconds
01:36:22: ISAKMP: SA life duration (basic) of 28800
01:36:22: ISAKMP: encaps is 2
01:36:22: ISAKMP: authenticator is HMAC-MD5
01:36:22: IPSEC(validate_proposal): invalid transform proposal flags -- 0x0
01:36:22: ISAKMP (0:1): atts not acceptable. Next payload is 0
01:36:22: ISAKMP (0:1): phase 2 SA not acceptable!
01:36:22: ISAKMP (0:1): sending packet to 172.16.21.228 (R) QM_IDLE
01:36:22: ISAKMP (0:1): purging node 314043992
01:36:22: ISAKMP (0:1): Unknown Input for node -1877728890: state = IKE_QM_READY, major = 0x00000001, minor = 0x0000000C
VPN2651#
01:36:22: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer at 172.16.21.228
VPN2651#
01:36:30: ISAKMP (0:1): received packet from 172.16.21.228 (R) QM_IDLE
01:36:30: ISAKMP (0:1): phase 2 packet is a duplicate of a previous packet.
01:36:30: ISAKMP (0:1): retransmitting due to retransmit phase 2
01:36:30: ISAKMP (0:1): retransmitting phase 2 QM_IDLE -1877728890 ...
01:36:30: ISAKMP (0:1): incrementing error counter on sa: retransmit phase 2
01:36:30: ISAKMP (0:1): no outgoing phase 2 packet to retransmit. -1877728890 QM_IDLE
VPN2651#
01:36:46: ISAKMP (0:1): received packet from 172.16.21.228 (R) QM_IDLE
01:36:46: ISAKMP (0:1): phase 2 packet is a duplicate of a previous packet.
01:36:46: ISAKMP (0:1): retransmitting due to retransmit phase 2
01:36:46: ISAKMP (0:1): retransmitting phase 2 QM_IDLE -1877728890 ...
01:36:46: ISAKMP (0:1): incrementing error counter on sa: retransmit phase 2
01:36:46: ISAKMP (0:1): no outgoing phase 2 packet to retransmit. -1877728890 QM_IDLE
VPN2651#
Re: Negotiation tunell between AIX and 2651
I haven't got the exact decode of the 0x0 proposal, but I would start on checking the defined transform proposal on the router against the peer, ie esp-des, esp-hmac-md5 and also the lifetime. Does the peer understand the lifetime in secs or only in kb, or both?
Thanks dor your reply...
As far as I know, peer is understanding lifetime both ways kb and seconds. I have requeswt more information from AIX specialists.
In any case, I understand that your first suggestion is to check with different proposals (as mentioned in other similar conversations); this is going to be dome tomorrow.
Hi again Cris,
first of all I will apologize for my spelling, I know it could be horrible for you...
We have tested again the tunnel an it works with no changes on C2651 config.
The only differences are:
AIX machine is another one, which has same system levels and fixes.
Some minor changes on AIX Phase 1 and Phase 2 params have been done (mainly lifetime values).
We are going to test again with the old Aix machine and will tell you the results...
In the other hand, we have been requested to get information about CA configuration between AIX and Cisco's routers. Could you give some feedback(supported or not, config samples, IOS required)?
Thanks for all your help
Iñaki.
108
