Nessus scan reloads CAT4006 with Sup II
js.franklin
I've got an associate that has auditors on site. When they begin a scan of one or 10 servers, within a few minutes the switch that the scanned devices are on reloads. WS-C4006 with (1) WS-X4013 and 3 WS-X4148RJ, CATOS 6.3(3) Has anyone encountered this issue?
Bobby Thekkekandam
It's likely some sort of unhandled exception in the cat code. 6.3(3) is very very old, so chances are that it's been fixed by now. 6.4(21) is the latest in the 6.3/6.4 train, so you may want to consider upgrading to that version.
Also, if you can post a show crashdump 1 as well as a show ver, I can try to decode it to see if it matches a known bug.
HTH,
Bobby
*Please rate helpful posts.
