netbios over Lan to Lan tunnel with NAT
m.reay
Has anyone successfully managed to run Netbios over a LAN to LAN tunnel where NAT is being used ie such as where the netowrks at either end of the tunnel have overlapping addresses.
Al other protocols work but udp 137 and 138 are not being natted.
ASA has a fixup/inspect for Netbios but I suspect the concentrator doesn't have this sophisticaion.
Thanks.
j-block
Level 4
Level 4
What OS is running on the domain controller that you can map to UDP?
