Community Member
Netflow on FR interface
I had a setup on my router which caused NetFlow stats to stop working.
(sh ip cache flow showed nothing)
**A - Starting config
ip flow-cache timeout active 1
ip flow-export source Serial0/0
ip flow-export version 5
ip flow-export destination aaa.bbb.ccc.ddd 12345
bandwidth 2048
ip address aaa.bbb.ccc.ddd
rate-limit output stuff...................
ip route-cache flow
no ip mroute-cache
no fair-queue
frame-relay map ip a.b.c.d 304 broadcast
frame-relay interface-dlci 304
frame-relay lmi-type cisco
**B - made NetFlow work (confirmed with sh ip cache flow) by doing
C_Node(config-if)# fair-queue
**C - reloaded and it stopped working
**D - reverted back to no fair-queue and it started working again!
**E - reloaded again and it stopped again (?)
and then I can go back to **B and it starts working and I'm in a loop
PS have I included enough config stuff
Re: Netflow on FR interface
The topic of this forum is Virtual Private Networks however there are a number of professionals online who may be able to assist you. We are always considering additional forums for such topics and I will make a note of your post.
If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center or speak with a TAC engineer. You can open a TAC case online at
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
