Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Network Auto Discovery: FAILED to create a tunnel !!
Dear All,
Does anyone using LAN-to-LAN with "Network Auto Discovery" ??
I am using the latest v3.6.7.C , and sometimes it generate errors as below
Would be very appreciated for any info on how to configure properly the Network Auto Discovery feature.
1605 03/31/2003 20:32:02.150 SEV=5 IKE/35 RPT=6 10.10.40.1
Group [10.10.40.1]
Received remote IP Proxy Subnet data in ID Payload:
Address 172.16.1.0, Mask 255.255.255.0, Protocol 0, Port 0
1608 03/31/2003 20:32:02.150 SEV=9 IKEDBG/1 RPT=61 10.10.40.1
Group [10.10.40.1]
Processing ID
1609 03/31/2003 20:32:02.150 SEV=5 IKE/34 RPT=6 10.10.40.1
Group [10.10.40.1]
Received local IP Proxy Subnet data in ID Payload:
Address 192.168.10.0, Mask 255.255.255.0, Protocol 0, Port 0
1612 03/31/2003 20:32:02.150 SEV=8 IKEDBG/0 RPT=665
QM IsRekeyed old sa not found by addr
1613 03/31/2003 20:32:02.150 SEV=4 IKE/61 RPT=5 10.10.40.1
Group [10.10.40.1]
Tunnel rejected: Policy not found for Src:172.16.1.0, Dst: 192.168.10.0!
1 REPLY
Bronze
Re: Network Auto Discovery: FAILED to create a tunnel !!
Check the protected network configuration in the LAN to LAN screen on
both sides and make sure that the local net on the initiator is the
remote net on the responder and vice-versa. Pay special attention to
wildcard masks, host addresses versus network addresses, etc. Non-Altiga
implementations may have the private addresses labeled as proxy addresses
or red networks.
81
