Network Design Guidelines
There is requiremet for setting up LAN+WAN+Security with Disaster Recovery mechanism in place.
Pls suggest on the design with respect to the attached requirements.
Attached existing topology LAN+WAN+Security setup.
With requirement draft.
1 REPLY
Silver
Re: Network Design Guidelines
It is very difficult to suggest a design without having the full information. I believe this will also involve a lot of design reviews before anything can be frozen. I suggest you to refer to some of the design documentaion on the Cisco web site.
92
