Community Member
Newb, Help me to configure my pix...
I have a PIX connected to a switch (Inside interface) and to a router (Ouside interface).
On the switch, I have somes servers. Each server have an ethernet inferface with a public ip address (on the network 80.64.226.1/24, the first address is my router). The servers have just one public port (tcp/80) and can be used to navigate on the internet with a browser.
Could you give me a simple configuration for my PIX with this information ?
Thanks a lot !
Jerome
1 REPLY
Purple
Re: Newb, Help me to configure my pix...
Try this:
nameif ethernet0 inside security100
nameif ethernet1 outside security0
ip address inside 80.64.226.1 255.255.255.0
ip address outside x.x.x.x 255.255.255.x
access-list 110 permit tcp any 80.64.226.0 255.255.255.0 eq www
static (inside,outside) 80.64.226.0 80.64.226.0 netmask 255.255.255.0 0 0
access-group 110 in interface outside
Hope that helps - pls rate the post if it does.
Paresh
103
