Highlighted
Community Member
Newbie - Help with Basic NAT on ASA 5505
Guys,
I have an ASA5505 that I need to configure as follows,
inside networks
192.168.4.0/24
192.168.5.0/24
outside network
10.96.112.20/24
All I want to do is that the inside networks all get translated to 10.96.112.20 and that I can manage the box using 10.96.112.20.
Don't need anything else, DHCP. Just basically NAT for now.
I have the box sitting in front of me with basic config.
Can anyone help a brother out ?
Hall of Fame Super Blue
Re: Newbie - Help with Basic NAT on ASA 5505
nat (inside) 1 192.168.4.0 255.255.255.0
nat (inside) 1 192.168.5.0 255.255.255.0
global (outside) 1 interface
This is assuming the outside interface of your pix is using the address 10.96.112.20.
To manage it from the outside you can use ssh or IPSEC. SSH is probably the way to go.
Jon
Community Member
Hi Jon, thanks for your reponse. How can I test this works before deploying it. I put a router on the inside and can ping the inside asa address. My laptop on the outside and can ping the outside asa address. They cannot see through the asa though ?
192.168.5.200 --> asa inside 192.168.5.234 ---> asa outside 10.96.112.20 ---> laptop 10.96.112.21
Appreciate any suggestions !
TIA
You need an access-list ie.
access-list acl_outside permit icmp any any
access-group acl_outside in interface outside
Then ping from router to laptop.
Jon
Community Member
Jon, I cannot seem to get this thing working. I am _so_ not the firewall person, this is my first:-) all I need to do is get this thing performing the NAT and so I can telnet to the outside address to manage it after it's installed at site - then the firewall peeps will take care of the rest :-) what am I doing wrong here ? Thanks again.
ASA Version 7.2(2)
hostname ciscoasa
enable password 8il5M/7PS/HH/mgc encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.5.234 255.255.255.0
interface Vlan2
nameif outside
security-level 100
ip address 10.96.112.15 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxxxxxxxxxxx encrypted
ftp mode passive
access-list acl_outside extended permit icmp any any
access-list acl_outside extended permit ip any any
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:0a4b8a707bce8a408f747562b06d4840
: end
Community Member
Hey Jon, thanks for all you help, I do appreciate it. I managed to get one of the firewall guys on it :-)
157
