NFS/RPC help needed
Basically we have a NFS server on the inside interface and a NFS client
on a lower security interface (but not the outside) when the portmap client
connects to the portmap server to find out the port of the corresponding mountd server the PIX doesn't seem to open a hole for this next connection.
This is causing hassles because we want to block ALL traffic except the essentials.
But now we have to allow ALL traffic to our NFS servers because the PIX cant
do a "fixup" for RPC.
The doco suggests it should work, but its very vague.
Any help would be much appreciated!
1 REPLY
Silver
Re: NFS/RPC help needed
If you are looking for a fixup for Microsoft RPC, the command you can use is:
established tcp 135 permitto 1024-65535. This allows the PIX to open up ports based on the TCP 135 connection. However, it would not work if you are doing NAT.
126
