Community Member
No connectivity from Inside to Outside Segments
Dear All,
I have the following test lab environment with a PIX 506E.
Internal Network Hosts
I have two laptops in each segment with and IP addresses. However, I'm unable to ping each other even though i have modified the ACL to permit IP any any (only for testing purposes!!)
The outside laptop can ping its default gateway (router) and the outside PIX interface.
The inside laptop can ping its default gateway (the PIX inside interface) without any problems. However, these two laptops cannt ping each other. I dont want to use any NATting as I'd be using real IP addresses in the production. But I can't get the test lab network working.
Also I'm not sure whether the Static Statement i have added is essential. No success even without that.
Thanks in advance.
PIX Version 6.3(4)
interface ethernet0 100basetx
interface ethernet1 100basetx
nameif ethernet0 outside security0
nameif ethernet1 inside security100
hostname pixfirewall
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
access-list acl_out permit ip any any
access-list all-ip-packet permit ip any any
pager lines 24
logging buffered debugging
mtu outside 1500
mtu inside 1500
ip address outside
ip address inside
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
static (inside,outside) netmask 0 0
access-group all-ip-packet in interface outside
route outside 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
: end
Re: No connectivity from Inside to Outside Segments
with pix v6.x, nat/global or static is a must do before pix would start forwarding packet between the interfaces. thus, the posted static statement is required.
regarding the pinging, i was wondering if the laptop has the default gateway set to router, and whether or not the router has a route for subnet
further, issue the command "debug icmp trace" on the pix. the output should provide more info, including the icmp traffic flow such as echo request and reply.
Try to use/add nat 0 instead of static nat (inside,outside)
-> nat (inside) 0
