No default-gateway when i connect to a PIX through VPN
Folks,
Any ideas why i do not get a default gateway when I VPN to my PIX.
Re: No default-gateway when i connect to a PIX through VPN
you do not get a default gateway.
all packets are just tunnelled to the vpn gateway host then dealt with from there.
sam
If the VPN is using PPTP then a default gateway does (at least should) get assigned, which is simply the address assigned to the connection from the pool. If the connection in this case doesn't get a gateway assigned then the remote host will not be able to connect to anything via the VPN. If this is a PPTP connection, check the box in the connection properties to use the remote default gateway.
Rik
108
