No Events Display After Upgrade to IEV S60
I'm not seeing any events displayed in IEV after upgrading to the latest signature version: S60.
No event_realtime_table events or any archived events will display.
I've had this happen on both a W2K Pro and Server box, rebooted both but no luck.
I uninstalled the S60 upgrade on the Server box and rebooted but no joy. The version now shows as S58 but no events show up.
Any suggestions?
Tony
Bronze
Re: No Events Display After Upgrade to IEV S60
There are a couple of things to check. On the IEV system, make sure the 'Cisco IDS Event Viewer' and 'MySQL' services are running. Also, make sure that you have a good connection to the sensor you are monitoring. Right click on the device and select 'Device Status'.
Both services were running but I restarted them and now I get a display. Go figure.
Thanks for the help.
Tony
148
