No traffic passing over a inbound port redirection
the setup : pix 501 with 1 public IP, 10 internal IP
trying to redirect http://public_ip:85 to internal webserver port 80.
I used static and access-list to do the port redirection.
access-list acl_out permit tcp any host 1.2.3.4 eq 85 (hitcnt=6)
static (inside,outside) tcp interface 85 192.168.1.100 www netmask 255.255.255.255 0 0
When trying to access http://public_ip:85 from externally...
show xlate is ...
PAT Global 1.2.3.4(85) Local 192.168.1.100(80)
show conn is ...
TCP out 12.225.151.29:16745 in 192.168.1.190:80 idle 0:00:03 Bytes 0 flags SaAB
Any help would be appreciated, I believe everything is configured correctly, there is just no data moving back and forth. Thanks.
Re: No traffic passing over a inbound port redirection
HI.
As you can see here:
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_62/cmdref/s.htm#1026157
The "flags SaAB" tells us that this is an embryonic connection - the external host has sent his SYN, but the internal host didn't respond.
This means - check the web server configuration.
Is port 80 open at the server?
Check the default gateway of the server - should be the pix inside.
Yizhar
Hi Yizhar,
Thanks very much, this fixed it. The internal webserver had a default gateway of 0.0.0.0. How'd you get so smart?
just to make sure: did you apply the access-list to the outside interface?
If not, use this command:
access-group acl_out in interface outside
Hope this help.
Kind Regards,
Tom
239
