no traffic through Concentrator
I am using the Concentrator 3000 - establishing VPNs from outside.
Authentification is successful ! Tunnel is UP !
but no traffic is routed through the concentrator.
Pinging a station from the VPN Client - TIMES OUT - though every station
is reachable from the Concentrator (using the PING command on that device)
Through the Tunnel no station is reachable anymore - NO FILTERS applied (respectively : ip any any)
Does anyone have an idea ?
thx a lot
Hans
1 REPLY
Re: no traffic through Concentrator
Make sure you have the private filter applied on the private interface and the public filter on the public interface. Then make sure on the client it doesn't have an ip address assigned on its internal network card, to be the same ip address range as you have allocated out of the ip pool on the concentrator. Also check the concentrator, tunnel default gateway is set to your internal router. The default g/w should be set to your isp router.
85
