No translation group found for icmp src management
Hi Guys,
Just trying to configure VPN on ASA5520. My Cisco VPN client gets connected but I cannot access the LAN. I checked the log and found something strange. Looks like all my inside hosts are trying to reply via the Management Interface!!! Why is that happening when I configured the VPN on my inside interface? Attaching my config as well as the log file that I found strange.The usual hapens, i get 1 ping response then request timed out
Thankx,
Victor
1 REPLY
Re: No translation group found for icmp src management
Hmm, that is a bit odd. I think it's because you have the security-level set to 100 on both the inside and the management interfaces, and it may be confusing the ASA.
If you're not really using the management interface, take the security level off it, or change it to something other than 100 (and 0) and see if that makes a difference.
1302
