No translation group found for tcp src outside:
I can't seem to figure it out, I have VPN client, i'm able to "dialin" to my PIX 515E 7.2(2) w/ ASDM 5.2(2), yet I can't access anything on the network, I'm getting one of these famouse "No translation group found for tcp src outside:192.168.1.129/49175 dst inside:192.168.1.251/65535", no matter what I do...
can someone help me here please?
thanks
1 ACCEPTED SOLUTION
Re: No translation group found for tcp src outside:
You are welcome dmitry. May I ask you to start a new conversation for Windows auth and finalize this question by rating+choosing the "resolved my issue" post?
someone please help me
Hi Alexus
You dont have an exempt nat rule defnition for this traffic. Please post your config and let me suggest the necessary change
*Please do not forget to rate helpful posts and choose "accept as answer" for post which solved your issue
: Saved
PIX Version 7.2(2)
hostname pix
domain-name default.domain.invalid
enable password ********** encrypted
names
interface Ethernet0
speed 100
duplex full
nameif outside
security-level 0
ip address 38.99.194.174 255.255.255.248
interface Ethernet1
nameif inside
security-level 100
interface Ethernet2
nameif dmz
security-level 10
ip address 216.112.241.29 255.255.255.248
passwd ********** encrypted
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group network alexus
description 24.185.136.252
network-object host 64.237.55.82
network-object host 24.185.136.252
network-object host 69.10.67.16
object-group network www
network-object host 38.96.132.42
network-object host 38.96.132.43
network-object host 38.96.132.44
access-list outside_access_in extended permit icmp any any echo
access-list outside_access_in extended permit icmp any any echo-reply
access-list outside_access_in extended permit icmp any any time-exceeded
access-list outside_access_in extended permit icmp any any traceroute
access-list outside_access_in extended permit ip object-group alexus any
access-list outside_access_in extended permit udp interface outside interface inside eq sip
access-list outside_access_in extended permit tcp any object-group www eq www
access-list tgn_splitTunnelAcl standard permit any
access-list inside_nat0_outbound extended permit ip any 192.168.1.128 255.255.255.248
pager lines 24
logging enable
logging asdm notifications
logging host inside 192.168.1.251
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip local pool ipp 192.168.1.129-192.168.1.134 mask 255.255.255.248
ip verify reverse-path interface outside
icmp unreachable rate-limit 1 burst-size 1
asdm image flash:/asdm-pix-522.bin
asdm history enable
arp timeout 14400
global (outside) 101 interface
global (dmz) 101 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 101 0.0.0.0 0.0.0.0
static (inside,outside) 38.96.132.42 192.168.1.251 netmask 255.255.255.255
static (inside,outside) 38.96.132.43 192.168.1.250 netmask 255.255.255.255
static (inside,outside) 38.96.132.44 192.168.1.234 netmask 255.255.255.255
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 38.99.194.173 1 track 1
route dmz 0.0.0.0 0.0.0.0 216.112.241.25 254
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
aaa-server aaasg-ntd protocol nt
aaa-server aaasg-ntd host 192.168.1.234
nt-auth-domain-controller ACIES
group-policy tgn internal
group-policy tgn attributes
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value tgn_splitTunnelAcl
username alexus password ********** encrypted privilege 15
http server enable
http 192.168.1.251 255.255.255.255 inside
http 24.185.136.252 255.255.255.255 outside
http 192.168.1.129 255.255.255.255 inside
http 69.10.67.16 255.255.255.255 outside
snmp-server host inside 192.168.1.251 community public
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
sla monitor 1
type echo protocol ipIcmpEcho 38.99.194.173 interface outside
sla monitor schedule 1 life forever start-time now
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
track 1 rtr 1 reachability
tunnel-group tgn type ipsec-ra
tunnel-group tgn general-attributes
address-pool ipp
default-group-policy tgn
tunnel-group tgn ipsec-attributes
pre-shared-key *
telnet timeout 5
ssh scopy enable
ssh 64.237.55.82 255.255.255.255 outside
ssh 192.168.1.251 255.255.255.255 inside
ssh timeout 5
console timeout 0
management-access inside
class-map class_sip_udp
match port udp eq sip
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
class class_sip_udp
inspect sip
service-policy global_policy global
ntp server 207.46.232.182 source outside prefer
tftp-server inside 192.168.1.251 /
smtp-server 192.168.1.234
prompt hostname context
Cryptochecksum:de5bd8bcc1ac9210e21e3bd28c779b1e
: end
[OK]
Alexus
1)Do not use a VPN pool which is covered by an interface of firewall. VPN pool is in same subnet with Inside interface.
2)Do not use "any" in NAT or split tunnel ACLs. Specify the networks
Do the following modifications
ip local pool vpnpool 172.16.100.1-172.16.100.254 netmask 255.255.255.0
no access-list tgn_splitTunnelAcl standard permit any
access-list tgn_splitTunnelAcl permit ip 192.168.1.0 255.255.255.0 172.16.100.0 255.255.255.0
no access-list inside_nat0_outbound extended permit ip any 192.168.1.128 255.255.255.248
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 172.16.100.0 255.255.255.0
crypto isakmp nat-traversal 20
no address-pool ipp
address-pool vpnpool
Recommendation: 192.168.1.0 is the network of most out of the box internet modem/routers' IP range, this will cause trouble if PC acquired IP address from one of them. You should change your inside interface ip range.
*Please do not forget to rate helpful posts and choose "resolved my issue" for the post that resolved your issue
ok, now it works, but i'm not able to "surf" at the same time whenever i'm vpnin
You dont have a DNS server specified for VPN clients. Do you have a DNS server or DC with ad integrated DNS at main office? If you have, then...
dns-server value DNSserverIPatmainoffice
If you dont have, then...
dns-server value 4.2.2.2
seems like after specifying dns it's able to resolve domains into IPs, yet looks like NAT isn't working for me
Please describe what you cant do and what you want to do right now and attach your current running-config
i would like to be able to surf internet while i'm vpn in, and if its possible to be able to have my users to authenticate against my windows 2003 active directory server (thats only if possible, if not then i'm ok without it) but browsing internet is important.
thanks in advance
pix(config)# wr t
: Saved
PIX Version 7.2(2)
hostname pix
names
interface Ethernet0
speed 100
duplex full
nameif outside
security-level 0
interface Ethernet1
nameif inside
security-level 100
interface Ethernet2
nameif dmz
security-level 10
ftp mode passive
access-list tgn_splitTunnelAcl extended permit ip 192.168.1.0 255.255.255.0 172.31.255.240 255.255.255.240
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 172.31.255.240 255.255.255.240
pager lines 24
logging enable
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip local pool ipp 172.31.255.241-172.31.255.254 mask 255.255.255.240
asdm history enable
arp timeout 14400
dns-server value 192.168.1.234
http server enable
sla monitor 1
encryption 3des
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
address-pool ipp
pre-shared-key *
telnet timeout 5
ssh scopy enable
ssh timeout 5
console timeout 0
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
class class_sip_udp
inspect sip
Cryptochecksum:f916a44904763c9c160e223db1a917d5
: end
[OK]
pix(config)#
"and if its possible to be able to have my users to authenticate against my windows 2003 active directory server"
We would handle it after we resolve internet issue.
In client, when VPN connected, issue the following commands in command line and paste here the outputs
nslookup
www.google.com
and
tracert 64.156.132.140
and finally
route print
Make sure you get the outputs of commands above while connecte to VPN
Microsoft Windows [Version 6.0.6000]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
D:\Users\a1exus>nslookup www.google.com
Server: UnKnown
Address: 192.168.1.234:53
Non-authoritative answer:
Addresses: 64.233.169.104, 64.233.169.99, 64.233.169.103, 64.233.169.147
Aliases: www.google.com
D:\Users\a1exus>tracert 64.156.132.140
Tracing route to www-level3.experts-exchange.com [64.156.132.140]
over a maximum of 30 hops:
1 * * * Request timed out.
2 * * * Request timed out.
3 * * * Request timed out.
4 ^C
D:\Users\a1exus>
D:\Users\a1exus>netstat -rn
Interface List
15 ...00 05 9a 3c 78 00 ...... Cisco Systems VPN Adapter
8 ...00 19 d1 e4 4b d0 ...... Intel(R) 82566DC Gigabit Platform LAN Connect
10 ...7a 79 05 6d 5c e3 ...... Hamachi Network Interface
1 ........................... Software Loopback Interface 1
23 ...00 00 00 00 00 00 00 e0 isatap.{80D152C1-EF16-4DEB-A624-81201E1AA5DD}
9 ...02 00 54 55 4e 01 ...... Teredo Tunneling Pseudo-Interface
24 ...00 00 00 00 00 00 00 e0 6TO4 Adapter
22 ...00 00 00 00 00 00 00 e0 isatap.WRVS4400N
29 ...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #3
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 172.31.255.242 172.31.255.241 266
10.10.10.1 255.255.255.255 On-link 10.10.10.10 100
38.99.194.174 255.255.255.255 10.10.10.1 10.10.10.10 100
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
172.31.255.240 255.255.255.240 On-link 172.31.255.241 266
172.31.255.241 255.255.255.255 On-link 172.31.255.241 266
172.31.255.255 255.255.255.255 On-link 172.31.255.241 266
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 5.109.92.227 9256
224.0.0.0 240.0.0.0 On-link 10.10.10.10 266
224.0.0.0 240.0.0.0 On-link 172.31.255.241 266
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 5.109.92.227 9256
255.255.255.255 255.255.255.255 On-link 10.10.10.10 266
255.255.255.255 255.255.255.255 On-link 172.31.255.241 266
Persistent Routes:
Network Address Netmask Gateway Address Metric
0.0.0.0 0.0.0.0 5.0.0.1 Default
0.0.0.0 0.0.0.0 172.31.255.242 Default
IPv6 Route Table
Active Routes:
If Metric Network Destination Gateway
24 1125 ::/0 2002:c058:6301::c058:6301
1 306 ::1/128 On-link
9 18 2001::/32 On-link
9 266 2001:0:4137:9e66:27:325f:53e0:e/128
On-link
24 1025 2002::/16 On-link
24 281 2002:56d:5ce3::56d:5ce3/128
On-link
8 266 fe80::/64 On-link
9 266 fe80::/64 On-link
22 266 fe80::5efe:10.10.10.10/128
On-link
29 266 fe80::5efe:172.31.255.241/128
On-link
9 266 fe80::27:325f:53e0:e/128 On-link
23 281 fe80::200:5efe:5.109.92.227/128
On-link
8 266 fe80::9170:2be2:270c:d7f6/128
On-link
1 306 ff00::/8 On-link
9 266 ff00::/8 On-link
8 266 ff00::/8 On-link
15 266 ff00::/8 On-link
Persistent Routes:
None
D:\Users\a1exus>
You dont have the following line in your current config, please add it
that seems to do the trick:)
thank you so much!
how 'bout windows authentication now?
ofcourse
thanks again,
it was very helpful
978
