No WINS/DNS using Certificate
I'm setting up remote VPN with the PIX 515 and the vpn client version 5.5.1.E-k9 and I'm having a problem passing the wins/dns information to the client using certificates to authenticate. If I set a password for the vpngroup, change my isakamp authentication to pre-share and login with the client everything works fine.
I think the problem is that I don't know how to tell the client what the vpngroup name is when using a certificate. Can somebody give me some advice?
kseraphine@goldenconcepts.net
1 REPLY
Re: No WINS/DNS using Certificate
The group name is the OU field on your certificate. So you would create a group with the same name, see:
http://www.cisco.com/warp/customer/471/unityclient-ios.html
it is for a router but it would be similar for the PIX.
82
