no xlate problems
pcguru1964
hello,
i am having some odd errors in a pix 515e log that states:
"Deny inbound (No xlate) udp src outside:192.168.2.1/137 dst outside:192.168.2.255/137"
the 2.1 address is from the vpn remote address pool. so it looks like the remote address is try to do netbios to the broadcast address of the ip pool.
anyone know what i can do to fix the problem? it is an annoyance more than anything. call me crazy but i like to see few errors on the logs.
thanks as bunch
wong34539
Level 6
Level 6
This message appears under normal conditions when internal users are using web browsers. It does not affect the performance however. Here's an extract from one of the documents on the error.
%PIX-7-106011: Deny inbound (No xlate) chars
Explanation : The message will appear under normal traffic conditions if there are internal users that are accessing the Internet via a web browser. Anytime a connection is reset, when the host at the end of the connection sends a packet after the PIX Firewall receives the reset, this message will appear. It can typically be ignored.
Action : Disable this syslog message from getting logged to the syslog server by entering the no logging message 106011 command.
For a detailed account of the interpretation of the error messages on a PIX, you could use the following document. I found it very useful and I hope it would clarify doubts regarding other error that you might see.
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_62/syslog/pixemsgs.htm
yes. this was quite helpful. thanks a bunch.
