12-03-2002 01:21 PM - edited 02-21-2020 12:12 PM
I have "debug crypto isakmp" "debug crypto ipsec" and "debug crypto engine" all turned "on" in my config, and have performed the "terminal monitor" command several times during my login. I connect externally to my PIX 520 - running 6.2(2) code - but do not see any crypto debug messages. Occasionally when I log out and reconnect, but before I type in a password, I get blasted with about one page worth of debug messages, but only when using Hyperterm. HELP?!?!? This makes troubleshooting VPN connectivity issues extremely difficult. I know this has worked before, for me personally, in the past, but now it no longer works....
12-09-2002 12:58 PM
I had a similar problem some time ago and the solution turned out to be pretty simple. The debug messages are sent out to one session only. All you need to do is to ensure that you'rs is the only session around and things should work fine.
12-09-2002 01:04 PM
Thanks, S-doyle, but I am positive that I am the only connection to that PIX. No one else has the ability to log in to that firewall. Plus, executing the 'who' command verifies that I am the only connection to it as well.
12-09-2002 01:05 PM
Also, sorry for the confusion - jrichv was an old cco login I had. This is my latest one - rvenable. Thanks again for the reply
