Not translating FTP PORT command
FTP not working, data channel not getting set up.
I did an outside capture and can see that although the inside addresses are being translated, and the control channel getting set up, when a PORT command is issued, the IP address in the command is the inside IP.
The server then responds with a
Response: 500 I won't op
Silver
Re: Not translating FTP PORT command
Do you have fixup protocol ftp enabled? Where is the PIX in this config?
This actually is an ASA, running version 7. Fixup is now "inspect" and is supposed to be enabled by default. I.e. I have no explicit FTP configuration.
The ASA is the Internet firewall.
200
