nr.managed beta workaround -- help with permissions
skeetin44
Can anyone please help.
I am trying to apply the workaround patch for the CSCdx55215 (telnet/des) bug.
I have got the nr.managed file to look like this:
-rwsr-s--- 1 root other 3037368 Jan 27 15:58 nr.managed
and not the way it should:
-rwsr-s--- 1 root netrangr 3037368 Jan 27 15:58 nr.managed
The problem that I run into, is that managed won't start, unless I correct that.
Can anybody help with the command, to get netrangr in there, where the other shows up?
Any help is appreciated,
E
stleary
Log into your sensor, become root, and try this:
# cd /usr/nr/bin
# chgrp netrangr nr.managed
# ls -al nr.managed
