09-04-2002 09:21 AM - edited 02-21-2020 12:02 PM
When I migrate to the version 3.5.3A to V.3.6 and V.3.6.1 my VPN3030 concentrator all IPSEC groups that needs NT authentication appears with no "NT DOMAIN" field in the vpn client window. If I inform "ntdomain\username" in the user field works well, but someone know if this is a BUG?
Thanks a lot for any help
Rogerio
09-13-2002 08:52 AM
I don't see any bugs listed. Have you asked tac yet? If so, what did you find out?
09-16-2002 05:26 AM
This question was commented at AUG 28 by awaheed.
I only saw the answer after my posting.
12-11-2002 01:37 PM
I have been looking, and can not find this post. Does anyone know where it is? AWAHEED?
Billy
12-11-2002 01:46 PM
This field was removed from 3.6 client, its not a bug.
Kurtis Durrett
12-11-2002 06:42 PM
Here is the message posted by awaheed on this topic:
Hi Felix,
Actually the Domain was never used in that option, so to avoid the confusion they took that option out in the latest client version.
It should work without a problem though, are you seeing any issues?
Aamir
Arul
12-13-2002 03:33 AM
If you change the authentication for a "Radius" or "Radius with Expiry" the field comes back. The Radius server can be done with MS-IAS.
Regards..
