Community Member
One-way data through LAN2LAN tunnel
Hi all!
I have a PIX terminating VPN Client connections. These connections work fine. Now I'm trying to end a lan-to-lan tunnel from a concentrator to the PIX. The tunnel can be opened from both ends, but data can only be sent from the concentrator to the pix. Even though data from the pix opens the tunnel, the concentrator never gets the packets. Any idea what might be wrong?
Here's some config from the pix:
Building configuration...
: Saved
PIX Version 6.1(1)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password ***** encrypted
passwd ***** encrypted
hostname pix
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
access-list 88 permit ip
access-list 88 permit ip host
access-list 89 permit ip host
pager lines 24
logging on
logging timestamp
logging console warnings
logging buffered warnings
interface ethernet0 auto
interface ethernet1 auto
mtu outside 1500
mtu inside 1500
ip address outside
ip address inside
ip audit info action alarm
ip audit attack action alarm
ip local pool VPN-pool
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list 88
nat (inside) 1 0 0
route outside 1
route outside 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server NTIAS protocol radius
aaa-server NTIAS (inside) host Kissa timeout 10
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set strongdes esp-3des esp-md5-hmac
crypto dynamic-map dynamap 20 set transform-set strongdes
crypto map vpnmap 10 ipsec-isakmp
crypto map vpnmap 10 match address 89
crypto map vpnmap 10 set peer
crypto map vpnmap 10 set transform-set strongdes
crypto map vpnmap 20 ipsec-isakmp dynamic dynamap
crypto map vpnmap client authentication NTIAS
crypto map vpnmap interface outside
isakmp enable outside
isakmp key ******** address netmask no-xauth no-config-mode
isakmp identity address
isakmp policy 8 authentication pre-share
isakmp policy 8 encryption 3des
isakmp policy 8 hash md5
isakmp policy 8 group 2
isakmp policy 8 lifetime 86400
vpngroup Grouppi address-pool VPN-pool
vpngroup Grouppi dns-server
vpngroup Grouppi wins-server
vpngroup Grouppi default-domain
vpngroup Grouppi idle-time 1800
vpngroup Grouppi password ********
telnet timeout 5
terminal width 80
: end
Community Member
Re: One-way data through LAN2LAN tunnel
Oh, stupid old me. The route statement was incorrect. A basic mistake.
