Open port 80 using outside IP
We are using Cisco ASA 5510 as a gateway. We are out of the public IP addresses for hosting web sites. Can we use the outside IP (public/WAN IP) for HTTP? If yes, what?s the command line?
1 ACCEPTED SOLUTION
Re: Open port 80 using outside IP
In PIX 7.x (similar to previous PIX 6.x), there is a feature called port redirection.
You need to statically mapped your internal/dmz server to your ASA outside interface IP and create ACL permitting incoming HTTP access.
Example:
access-list outside permit tcp any host 172.18.124.216 eq www
ip address outside 172.18.124.216 255.255.255.0
static (inside,outside) tcp interface www 10.1.1.5 www netmask 255.255.255.255 --> the 'interface' refers to Outside interface IP, the 10.1.1.5 is your internal server
access-group outside in interface outside
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00804708b4.shtml
Rgds,
AK
Silver
Yes that is possible. What you need is static pat. The following URL has additional information on this:
http://www.cisco.com/warp/public/707/28.html#topic9
Example:
Rgds,
AK
104
