Opening a port for SAP on PIX 506
I am having SAP servers on my network which I need external users to use , what access-list command should I be using for that. SAP uses tcp port 3200.
access-list 111 tcp ???
Also how can I can check if my firewall is stopping all unauthorized access ??
Re: Opening a port for SAP on PIX 506
You have to setup a static translation for each internal SAP server and create an access-list that states who can access what. the following example assumes:
internal server address : 172.16.1.1
external ip address for internal server: 200.1.1.1
external IP address that can access the server: 204.2.2.2 and 204.3.3.3
static (inside,outside) 200.1.1.1 172.16.1.1 netmask 255.255.255.255
access-list inbound permit tcp host 204.2.2.2 host 200.1.1.1 eq 3200
access-list inbound permit tcp host 204.3.3.3 host 200.1.1.1 eq 3200
access-group inbound in interface outside
I hope this helps.
Thanks that would really help, but the locations who are going to access my SAP servers do not have a static IP.
Also is there any way I can check whether my access-list are correct & unauthorized access is not allowed.
In that case you need to use the 'any' keyword for the source IP addresses.
To verify if your acl entries are correct, you need to have it checked by a experienced PIX person.
Thanks buddy....that did work superbly
thanks again.
183
