02-02-2003 06:21 PM - edited 02-20-2020 10:32 PM
I've got a 515 Pix Firewall that I wanted to check if port 110 was open because I cannot POP3 into our Exchange server. I never worked on a Cisco firewall so I do not know any commands. Could you tell me how to check this on the firewall and also the command to open this port if it is closed as I suspect.
Dennis
02-02-2003 06:48 PM
to verify use sh access-list, show conduit, everything inbound is denied unless explicitly permitted
02-03-2003 12:16 AM
Thanks for the reply. Would you know the command to open this port.
Dennis
02-03-2003 02:06 AM
Hi Dennis,
Here is a cisco document that will help you out :
http://www.cisco.com/warp/public/707/28.html
If you need help let me know, hope this helps.
Jay.
02-03-2003 03:05 PM
Hi Jay,
Thanks for the reply. As I mentioned earlier, I've never used a Cisco firewall before so the doc that you pointed me to looks all "Chinese". I hope you understand what I mean. Look the firewall is working fine and I don't want to change anything else. All I want to do is open port 110 so that I can POP3 to my Exchange server that behind this firewall. If you could tell me the commands to do this, that would be really helpful.
Dennis
02-04-2003 01:28 AM
Hi Dennis,
Any chance you can paste your pix config (exclude private IP + Passwords) so that I can show you what to do ?
Jay.
02-03-2003 08:39 PM
you should already have a static to your exchange box (mail server) and a conduit allowing mail from the mailserver your ISP gave you. (port 25). Do the same statement for port 110 and you should be fine.
