OpenSSH buffer management errors in IDS 3.x Fix Available ??
hi
customer asked to know if fix is already available
for this issue ?? or when it will be available
thanks in advance
JYP
Re: OpenSSH buffer management errors in IDS 3.x Fix Available ??
It is currently being tested and is not yet available.
I am not sure when testing will be complete.
Until then the IDS users should restrict access to the IDS boxes by configuring the Allowed Hosts.
Allowed Hosts should be restricted to only those ip addresses that need access to the IDS sensors.
If a user tried to attack the sensor from an IP address not in the list of allowed hosts the connection will be dropped by TCP Wrappers and will not be sent to the ssh server.
So the sensor is not vulnerable to attacks from IP Addresses not listed in the Allowed Hosts.
Refer to the following links for configuring Allowed Hosts. It is best practice to limit the list of IP as much as possible to reduce exposure.
Using IDM: http://www.cisco.com/univercd/cc/td/doc/product/iaabu/csids/csids8/13876_01.htm#xtocid18
Using sysconfig-sensor: http://www.cisco.com/univercd/cc/td/doc/product/iaabu/csids/csids8/13870_01.htm#xtocid13 (step 13)
NOTE: In version 4.x sensors the Allowed Hosts has been renamed to the network access list.
Using 4.x CLI setup command: http://www.cisco.com/univercd/cc/td/doc/product/iaabu/csids/csids10/hwguide/hwchap9.htm#587561 (step 12)
Using IDM: http://www.cisco.com/univercd/cc/td/doc/product/iaabu/csids/csids10/idmiev/swchap2.htm#443188
thanks for this clear information
JYP
98
