OS 6.2 cutting TCP connections after +- 5 Minutes
I was running OS 5.3 and conduit sintax and all works fine. I´ve upgrade
to 6.2 version + PDN 2 . After this, all TCP connections are destroyed after +-
5 minutes. I´ve changed to access-list sintax too and the problem does not go away.
Re: OS 6.2 cutting TCP connections after +- 5 Minutes
I just installed 6.2 on a PIX 525. I was worried about your post since it would affect me as well. I set up a temporary access list to allow telnet sessions from an outside host to an inside host. Sessions stay up for as long as I keep them open. I can't duplicate this problem. Best to check with TAC.
i´ve installed the same configuration in another PIX 515
and the problem does not appear.I think its a hardware problem.
I found the problem. inversion 6.2
the "conn timeout 00:00:00" does not work. All TCP connection ( idle or not)
live only 2 minutes...
90
