outlook problems with vpn client to vpn 3030
users are experiencing disconnects when using outlook via the latest vpn client connecting to a vpn 3030 running the latest os. mtu settings have been adjusted many times, this does not help.
Re: outlook problems with vpn client to vpn 3030
This seems to be the MTU, maybe lowering it on the actual server migth help, also try lowering it using Dr. TCP aswell, sometimes it fixes it right away, for further troubleshooting feel free to contact the TAC.
Aamir
we've tried every setting on the client. do you mean on the mail server?
Hi, We have also been having a problem similar to this and I am happy to say that we have fixed the problem by uninstalling any old clients and installing vpn client 3.6. We also left the mtu setting at it's new default, 1300. If you read the release notes, it changes the way it interacts with Windows XP and fixes a few more issues. Give it a try.
okay, thanks. did you upgrade the os as well on the vpn box?
119
