Passive FTP does not work from outside through static all ports open
Have ftp clients connecting from the outside of a pix to a FTP server on the inside. Active FTP and passive FTP works fine internally. Have one to one static mapping of a global ip address on the outside to the ftp server on the inside. Active FTP from the clients work fine but passive FTP does not work. Infact opened all the ports using conduit still does not work.
This what I have already done.
1 Opened all ports for the FTP server.
2 Configured norandomseq on the static.
Will disabling fixup ftp help
Version of pix code 6.01.
Also another question. Although I enter norandomseq option for a particular static statement it does not reflect in the running config. Is it a default option or is there something wrong in the code. Tried removing the static command and adding it back with the norandomseq option.
Any help would be appreciated
Re: Passive FTP does not work from outside through static all po
disabling the 'fixup protocol ftp' will no solve your problem. If you do that, the active ftp will also stop working.
With active ftp, both the 'control' and the 'data' channel are initiated by the client. With passive ftp the client initiates the 'control' channel and the server initiates the 'data' channel. So something is preventing the ftp server to setup the 'data' channel back to the client.
Is there an access-list applied to the inside interface preventing the server to setup the data channel?
Is it possible to try replacing the 'conduit' commands with 'access-list' commands?
If it still does't work, could you please post the config (!!replace public addresses and passwords!!)?
Kind Regards,
Tom
Thanks for the reply.
There is a outbound statement on the inside but it is not denying any traffic from the FTP server.
here are a few suggestions that I would try:
- upgrade the PIX OS to the latest version
- remove the outbound statement for a moment and see what happens?
- remove all the 'outbound' and 'conduit' statements from the config and replace them with 'static', 'access-list' and 'access-group' commands (conduit and outbound command are kind of outdated).
Kind Regards,
Tom
98
