Bronze
Passive-ftp on an ASA
Ran into an issue trying to allow for passive-ftp on an ASA 5520. I have enable the ftp mode passive, even went so far as to allow an "ip any" to the FTP server in the DMZ and disable the global filtering policy. The client will connect, but cannot transfer files. Any ideas?
Re: Passive-ftp on an ASA
Hello sean@managednetworks.com,
The client should be initiating both connections to the ftp server. What do the logs show when you try to ftp?
find out which port range your ftp server is connecting on and define object services including ftp, ftp-data and the port range eg 1025 3500
Had similar problem and this is how I got round it.
Same issue here. Waiting for TAC reply, but would be curious to know if you resolved this.
Bronze
The issue turned out to be with the customer's FTP server. There was a setting that they did not have correct. ftp mode passive should be all that you need. Sometimes you may have to go into the default global policy and remove the ftp inspect portion. Hope this helps.
439
