password for netrangr
a-bhasin
We have lost the password for "netrangr" , Is there any way to reset it to default / new value without entering the new value ?
giovanni
Assuming you mean the Solaris-based sensor, just log on as root and use passwd.
If you've lost the root password I think you have to use the procedure described in:
http://www.cisco.com/warp/customer/474/34.html
Giovanni
Thank you , I was able to change after logging in as "root"
Thanking you once again
deb
