03-24-2004 09:40 PM - edited 02-20-2020 11:18 PM
Hi ...
I am New to Security.
I have a router(2600),Linux Proxy with 200 users.
I wanna to enable my firewall with linux proxy.
here is my config
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 auto This is for enabling the particular interface
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password yMQsZfE0puy6mcN6 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname syntax-firewall
domain-name syntaxsoft.com
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 61.x.x.x 255.255.255.224 Assinging the IP address
ip address inside 192.200.x.x 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 61.x.x.1.0-61.x.x.5
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 61.x.x.x 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
aaa proxy-limit disable
aaa authentication secure-http-client
http server enable
http 192.200.20.x 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
also my linus having 2 ethernet port one is assigend as Private Ip and other one as Public Ip.
can u send me an exact config file with sample configuration
waiting for reply
Jay
03-24-2004 10:20 PM
If you want to only allow Linux Proxy to go to the internet and deny all other PC, if they try to bypass the proxy, then do the following
nat (inside) 1
Nadeem
03-24-2004 11:10 PM
yes ur rite ,I want to allow only my linus proxy to get out
as per ur advise I have enabled the following command
nat (inside) 1
stil I am getting error as follows in debugging mode,still I am not able to browse
710005: UDP request discarded from 192.200.20.25/137 to inside:192.200.20.255/ne
tbios-ns
(this is my machine IP)
710005: UDP request discarded from 61.95.x.x/2301 to outside:255.255.255.255
/2301(this is Linus proxy global IP)
710005: UDP request discarded from 192.200.20.153/2301 to outside:255.255.255.25
5/2301(this is mail server IP local)
can u advise on the followig
1.wht could I make for browser setting.
2.My lan network is 192.200.20.0 series (is it make any differnce)
3.without fire wall I am using browser setting as with tht Proxy Ip with the port 3152.
waitinf for ur favourable reply
thanx a lot
Cheers
Jay
03-24-2004 11:14 PM
nat (inside) 1
tbios-ns
thanx a lot
Cheers
Jay
03-25-2004 10:56 AM
The above messages are not related to your issue. As i said your configs looks good. this seems to be a design issue.
you said your linux proxy has two ip, one private and one public, so probably linux is directly tryign to reach the internet. what is the public ip is it one of the range of pix public network. if so, then how would you redirect your traffic to the inside interface
for answers to your question
1... Your browser should be pointing to your proxy server (provided you want to use the proxy)
2... You LAN network IP doesnot make any difference. What is the private and public IP of your proxy?
03-25-2004 08:26 PM
Hi ...
thanx for ur response.
I forgot to write one issue.Rite now I am testing with my single PC with firewall.
i.e
cross cable
PC ------------ Fire stright cable
(inside) wall --outside----- Lan Port
also Inside,PC,one of the proxy are in 192.200.20.x series.
Outside,router and one of the proxy are 61.95.x.x same series.
May I am doing rite plz clarify me
If suppose I am doing like any routing should add or wht.
also above config I have added my routing proxy,still It is not working.
any one can plz help me out
my Yahoo ID is jk_jin@yahoo.com
interested plz help me in chat.
waiting for favouravle reply
thanx
J.Jayakumar
03-29-2004 09:25 PM
thanx for ur suggestion
my network detials
router
1.ehternet IP - 61.x.x.x(public IP)
2.Serial Ip - 202.x.x.x
Firewall
1.e0(outside)-61.x.x.x(public IP)
2.e1(inside)-192.200.x.x(Lan IP)
linux proxy
1.192.200.x.x(Lan IP)
2.61.x.x.x(public IP)
also I am coneecting with single PC where I am coneecting my ethernet port to inside port of Firewall using cross cable and outside of firewall I am connecting to mu LAN port,
is it make any difference to testing the firewall.
plz advise on this.
