Community Member
PDM 3.0(1)
I have a PIX-535 with :
Cisco PIX Firewall Version 6.3(1)
Cisco PIX Device Manager Version 3.0(1)
The problem is then I run PDM and in configuration file appear a lot of pdm location and pdm group lines with all IP Address and Groups used.
Sorin
1 ACCEPTED SOLUTION
Gold
Re: PDM 3.0(1)
Hello Sorin,
Here is the answer I obtained from Cisco on the PDM location in the PIX config :
A PDM location is a pure book keeping command used by PDM to build its topology
database.
It has nothing to do with the PIX's functionalities. In particular, it
does
**NOT** control which host can access PDM which is a common
misunderstanding.
The control is done by the command "http ".
Why do we need it?
In PDM's world, policy (those rules) is built on top of topology.
Ideally user creates the topology first via the Host/Network tab, then
configures policy else where (like Access Rule tab). A network object
exists by itself, even if there is no policy configured directly on it
at a particular time. We use "pdm location" command to remember the
location
of a network object.
Hope this explains it..
If this answers your question please rate this post, thanks.
Jay.
1 REPLY
Gold
Re: PDM 3.0(1)
Hello Sorin,
database.
does
misunderstanding.
Why do we need it?
location
Jay.
84
